[gdal-dev] RFC 73 merged in master / PROJ master required
Even Rouault even.rouault at spatialys.com
Fri Feb 1 04:52:59 PST 2019
I've got a few questions regarding build GDAL master.
I've initiated
https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev
with a few advice. Please correct/expand it as needed
Even
> All,
> RFC 73 work has now been merged into master. Currently GDAL build
> and runtime now depends on PROJ master
> More details of the past month work at:
> https://erouault.blogspot.com/2019/01/srs-barn-raising-8th-report-ready-for.
> html
> Let me underline its conclusion:
> """As all those changes done those last months deeply impact SRS related
> functionnality in GDAL and PROJ, we rely now on your careful testing to
> spot the inevitable issues that have not yet been detected by their
> respective automatic regression test suites. The earlier they are detected,
> the easier they will be fixable, in particular if they impact the API."""
> Even
http://www.spatialys.com
