[gdal-dev] ogr2ogr dxf multilinestring as block
andrew terry
andrew.terry at centremaps.co.uk
Tue Feb 5 03:40:26 PST 2019
Hi Alan,
I've found that by having a postgres table "blocks", that is an ogr layer
and i can get a cad file out which has the block in it.
Not sure whether i can call two tables with ogr2ogr but at worst i can run
the command once to create a template dxf to use as a header for my entities
to output as.
Thanks
Andy
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
