[gdal-dev] Reading JPEG2000 File
Christoph Paulik
cpaulik at vandersat.com
Tue Feb 5 04:41:18 PST 2019
I installed an up-to date version of gdal from conda forge.
But of course it all depends on which version you are currently using
and what your exact error is.
It is probably best if you go back to the package distributor.
On Tue, 5 Feb 2019 at 13:34, bhandari <bhandari.ravi at outlook.com> wrote:
> Thank You Christoph but trying that link did not work for me.
> Could you please tell how did you solve the problem
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Christoph Paulik // Head of Infrastructure
VanderSat // Satellite observed water data. Globally. Daily.
Wilhelminastraat 43a, 2011 VK, Haarlem (NL), The Netherlands
M +31 6 18271928 W www.vandersat.com
