[gdal-dev] Issue with OCI driver
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Feb 6 04:42:35 PST 2019
I believe that OCI driver does not honour the -t_srs parameter of ogr2ogr.
Use the driver specific layer creation option -lco SRID=4326 instead when
saving data into Oracle https://gdal.org/drv_oci.html.
You asked if it is possible to convert data into EPSG:4326 without knowing
the reference system used in source . I ask How could it be possible? With a
good guess perhaps, sometimes, but generally not. If GDAL cannot the SRS
automatically from the data source then user must give it with -s_srs.
-Jukka Rahkonen-
san619 wrote
> i tried to extract shapefile data table from oracle to shapefile.
> But im getting error :
> *Can't transform coordinates, source layer has no
> coordinate system. Use -s_srs to set one.
> ERROR 1: Terminating translation prematurely after failed
> translation from sql statement.*
> I tried exporting using command
> *ogr2ogr -f OCI OCI:user/password at ip/servicename -a_srs EPSG:2180
> "C:Downloads\pas_ochronny\pas ochronny.shp"*
> The file got uploaded successfully.But when im trying to extract the table
> to shapefile im getting error.
> I used the command
> ogr2ogr -f "GEOJSON" "PRO.json" OCI:user/password at ip/servicename -t_srs
> EPSG:4326 -sql "SELECT * FROM PAS_OCHRONNY"*
> but im getting the error Can't transform coordinates, source layer has no
> But when is used the command
> *ogr2ogr -f "GEOJSON" "PROPERTYs.json" OCI:user/password at ip/servicename
> -s_srs EPSG:2180 -t_srs EPSG:4326 -sql "SELECT * FROM PAS_OCHRONNY"*
> Translation got successful.Why like this.
> How to set the source layer coordinates while uploading.
> Is there any way to reproject any source datum to EPSG:4326 without
> knowing
> source.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
