[gdal-dev] Differences between OSRImportFromEPSG and OSRImportFromProj4
Even Rouault even.rouault at spatialys.com
Thu Feb 7 01:13:29 PST 2019
Hi Sean,
> I observe a difference between the WKT exports of OSRImportFromEPSG(osr,
> 3857) and OSRImportFromProj4(osr, "+init=epsg:3857"). The former gives a
> named coordinate system, the latter gives an unnamed coordinate system.
> Am I wrong to understand the semantics of "+init=epsg:3857" as "open the
> epsg database, get entry 3857, and use that"? Is this different from
> specifying the entry directly?
That's an case where my recent work will help reducing the confusion
(hopefully)
In current released versions, OSRImportFromEPSG() read in the GDAL data/*.csv
files a fully-fledged description of the geodetic object.
OSRImportromProj4("+init=epsg:XXXX") goes to PROJ which opens the $prefix/
share/proj/epsg file, identifies the PROJ string in it that corresponds to the
code, returns it to GDAL, and GDAL reconstructs a OGRSpatialReference by
analysing the PROJ4 string, which has no names.
With the RFC73 related work, now there's a single database. The
+init=epsg:XXXX syntax is still supported as a legacy mechanism by PROJ, but
it no longer opens a 'epsg' file but rather goes to the proj.db database. Note
that for backward compatibility purposes, if you use the +init=epsg:XXXX
syntax, PROJ will return CRS objects with possibly a non-EPSG compliant axis
order (for example it will return longitude-latitude for geographic CRS,
whereas EPSG mandates latitude-longitude). GDAL (with the commit I just pushed
since the +init=epsg:XXXX case was actually broken in master) will now emit a
warning if you use that legacy syntax.
$ gdalsrsinfo EPSG:4326 -o WKT2
GEOGCRS["WGS 84",
    DATUM["World Geodetic System 1984",
        ELLIPSOID["WGS 84",6378137,298.257223563,
            LENGTHUNIT["metre",1]]],
    PRIMEM["Greenwich",0,
        ANGLEUNIT["degree",0.0174532925199433]],
    CS[ellipsoidal,2],
        AXIS["geodetic latitude (Lat)",north,
            ORDER[1],
        AXIS["geodetic longitude (Lon)",east,
            ORDER[2],
    USAGE[
        SCOPE["unknown"],
        AREA["World"],
        BBOX[-90,-180,90,180]],
    ID["EPSG",4326]]
vs
$ gdalsrsinfo +init=epsg:4326 -o WKT2
Warning 1: +init=epsg:XXXX syntax is deprecated. It might return "
a CRS with a non-EPSG compliant axis order.
GEOGCRS["WGS 84",
            LENGTHUNIT["metre",1]],
        ID["EPSG",6326]],
        ANGLEUNIT["degree",0.0174532925199433],
        ID["EPSG",8901]],
    CS[ellipsoidal,2],
        AXIS["longitude",east,
            ORDER[1],
            ANGLEUNIT["degree",0.0174532925199433,
                ID["EPSG",9122]]],
        AXIS["latitude",north,
            ORDER[2],
                ID["EPSG",9122]]],
    USAGE[
        SCOPE["unknown"],
        AREA["World"],
        BBOX[-90,-180,90,180]]]
In the later, the axis roder is long/lat and the ID["EPSG",4326] node has been
stripped off since the object is not conformant with EPSG.
Even
http://www.spatialys.com
