[gdal-dev] Extracting vector layers from Geospatial PDF
Rajesvari Parasa
prkrajesvari3 at gmail.com
Sat Feb 9 11:47:46 PST 2019
Hi Tobias,
Thank you for suggesting this. I used the config option and my geospatial
content was intact. Here's the command:
ogrinfo ELU_PD_08_03.pdf --config OGR_PDF_READ_NON_STRUCTURED YES
it lists all relevant layers. Copy the name of the layer (say "Layername")
you want to write in shapefile and then:
ogr2ogr –f “ESRI Shapefile” footprint.shp ELU_PD_08_03.pdf Layername
I didn't know that *ogrinfo takes config options*. This is quite
interesting because the document of ogrinfo doesn't mention this.
Thanks again!
On Thu, Feb 7, 2019 at 1:20 AM Tobias Wendorff <
tobias.wendorff at tu-dortmund.de> wrote:
> Hi there,
> Am Mi, 6.02.2019, 17:58 schrieb Rajesvari Parasa:
> > to try: ogr2ogr -f sqlite out.sqlite in.pdf
> > But since ogr doesn't recognize my PDF, I can't use this.
> I had to use "--config OGR_PDF_READ_NON_STRUCTURED YES" to make it
> read my PDFs, but I think, this will destroy your Geospatial content.
> I've just read it in non-structured and georeferenced it using
> ground control points:
> ogr2ogr -progress -a_srs EPSG:3857 -gcp ... output.geojson input.pdf
> --config OGR_PDF_READ_NON_STRUCTURED YES -NLT polygon
> Perhaps this helps :/
> Best regards,
> Tobias
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190210/0ee91597/attachment.html>
