[gdal-dev] MSSQL Driver on Mac (Andreas Oxenstierna)
Andreas Oxenstierna ao at t-kartor.se
Wed Feb 13 22:56:41 PST 2019
We (so I do not remember the details) managed to get it working circa 5
years ago using unixODBC.
Since then, Microsoft have released an official ODBC driver for macOS,
https://www.microsoft.com/en-us/download/details.aspx?id=56567
> This is a tricky driver.  It uses ODBC (iODBC on macOS).  You need an
> ODBC driver for the MSSQL database for the Mac's iODBC.  GDAL doesn't
> know about installed ODBC drivers until you try to use them, so
> ogrinfo --formats will say MSSQL is supported.
> I don't know if any ODBC drivers are available on macOS for MSSQL.
>> On Feb 13, 2019, at 2:39 PM, Horn, Ian I (COT) <Ian.Horn at ky.gov
>> <mailto:Ian.Horn at ky.gov>> wrote:
>> Andreas, here’s what I get when:
>> Ians-iMac:~ ianhorn$ ogrinfo --formats | grep MS
>>   MSSQLSpatial -vector- (rw+): Microsoft SQL Server Spatial Database
>>   XLS -vector- (ro): MS Excel format
>>   XLSX -vector- (rw+v): MS Office Open XML spreadsheet
>>> On Feb 13, 2019, at 3:00 PM, gdal-dev-request at lists.osgeo.org
>>> <mailto:gdal-dev-request at lists.osgeo.org> wrote:
>>> Send gdal-dev mailing list submissions to
>>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>> gdal-dev-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of gdal-dev digest..."
>>> Today's Topics:
>>>   1. Re: MSSQL Driver on Mac (Peter Petrik)
>>>   2. Re: MSSQL Driver on Mac (Andreas Oxenstierna)
>>> Message: 1
>>> Date: Wed, 13 Feb 2019 15:26:06 +0100
>>> From: Peter Petrik <peter.petrik at lutraconsulting.co.uk>
>>> To: "Horn, Ian I (COT)" <Ian.Horn at ky.gov>
>>> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
>>> Subject: Re: [gdal-dev] MSSQL Driver on Mac
>>> Message-ID:
>>> <CA+T_MsJpeSiwaDwCtm3zqRnMt_8ftRO_KJ4urje0kgA0uw5nYw at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi, which installation do you use?
>>> Cheers,
>>> Peter
>>> On Wed, Feb 13, 2019 at 3:14 PM Horn, Ian I (COT) <Ian.Horn at ky.gov>
>>> wrote:
>>>> I am trying to access a SQL Server on QGIS, but I get the “error
>>>> opening
>>>> connection:  Driver not loaded Driver not loaded”.  QGIS installs GDAL
>>>> 2.3.2.  On my PC I know how to get to the root folders and check to
>>>> see if
>>>> the driver is there but not on my Mac.  If I use my terminal I get the
>>>> following:
>>>> Unable to open datasource
>>>> `mssql:server=XXXXXXXXX;database=XXXX;tables=XXXXX.TrafficCameras;XXXXXX;
>>>> ' with the following drivers.
>>>> How do I install or make this driver work on my Mac for both
>>>> command line
>>>> and use in QGIS?
>>>> Thanks,
>>>> Ian
>>>> _______________________________________________
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL:
>>> <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190213/a0a61fdb/attachment-0001.html>
>>> Message: 2
>>> Date: Wed, 13 Feb 2019 15:27:54 +0100
>>> From: Andreas Oxenstierna <ao at t-kartor.se>
>>> To: gdal-dev at lists.osgeo.org
>>> Message-ID: <0a58531e-caab-7ce7-f0de-d1fd58917530 at t-kartor.se>
>>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>>> What is ogrinfo reporting?
>>> For me (macOS 10.14.2 GDAL 2.3.2) it reports:
>>>> opening connection:  Driver not loaded Driver not loaded”.  QGIS
>>>> installs GDAL 2.3.2.  On my PC I know how to get to the root folders
>>>> and check to see if the driver is there but not on my Mac.  If I use
>>>> my terminal I get the following:
>>>> How do I install or make this driver work on my Mac for both command
>>>> line  and use in QGIS?
>>>> Thanks,
>>>> Ian
>>> Hälsningar
>>> Andreas Oxenstierna
>>> T-Kartor Geospatial AB
>>> Olof Mohlins väg 12 Kristianstad
>>> mobile: +46 733 206831
>>> mailto: ao at t-kartor.se
>>> http://www.t-kartor.com
>>> URL:
>>> <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190213/0fbf5c3a/attachment-0001.html>
>>> Subject: Digest Footer
>>> End of gdal-dev Digest, Vol 177, Issue 19
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> The equator is so long, it could encircle the earth completely once.
Hälsningar
Andreas Oxenstierna
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190214/82db1ed3/attachment.html>
