[gdal-dev] GDALWarp Datasets
James McClain james.mcclain at gmail.com
Fri Feb 15 04:36:27 PST 2019
Hello,
Okay, all of that is well-taken.  Thank you for your response.
> If you're not interested in the pixel values, using
GDALSuggestedWarpOutput2()
is a better fit.
Yes, my question was worded a bit unclearly: I am essentially interested in
retrieving warped tiles so the pixels are of primary interest.
Thank you,
James McClain
On Fri, Feb 15, 2019 at 4:58 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 15 février 2019 00:06:28 CET James McClain wrote:
> > Hello,
> > If I may, I would like to a few questions regarding how best to use the
> > GDALWarp function (
> https://github.com/OSGeo/gdal/blob/master/gdal/apps/gdalwarp_lib.cpp#L748-L7
> > 70) and the datasets that it creates.
> > In particular, I am experimenting with using such datasets to read warped
> > extents on an on-demand basis and in a thread-safe way.
> > I have found that the VRT output format is lazy with respect to
> computation
> > and allocation which is great for my use case, but it appears not to be
> > thread safe with respect to reading from a single warped dataset from
> > multiple threads.
> No single GDALDataset object of any driver should be used simultaneously
> by
> multiple threads (this extends to any GDAL/OGR class instance). If this
> seems
> to work for GTiff, you're just lucky, but that might just fail as well.
> If you need to access a dataset from several threads, each one should have
> its
> own GDALDataset object (so this won't work for the MEM driver)
> > On a more meta level, are datasets created by GDALWarp the right approach
> > (if I want to lazy get warped extents in a thread-safe manner) or should
> I
> > look elsewhere?
> is a better fit.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
"I prayed for freedom for twenty years, but received no answer until I
prayed with my legs."
     -- Frederick Douglass
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190215/dce0e03d/attachment.html>
