[gdal-dev] FileGBD vs OpenFileGBD, a few of questions
Andrea Aime
andrea.aime at geo-solutions.it
Mon Feb 18 03:51:30 PST 2019
On Mon, Feb 11, 2019 at 6:36 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> OpenFileGDB is certainly one that would benefit the most from datasource
> pooling, but all others can also, like the ones ingesting the dataset in
> memory, or having to do an initial full scan to determine the feature
> schema
> (GeoJSON)
One more question... say I'm doing pooling and at one point I want to open
a DataSource
in write mode. Do I need to close the ones in read mode? If not, would it
best to drop the
pool once the write is done?
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190218/e1f66568/attachment.html>
