[gdal-dev] Troubles in coord conversions with GDAL+proj6
Even Rouault
even.rouault at spatialys.com
Sun Feb 24 05:29:24 PST 2019
Joaquim,
> I'm having troubles migrating some of my Matlab mex to recent GDAL (built
> yesterday from git). With older GDAL versions all went well. For example,
> this is correct
> >> prj.SrcProjSRS = '+proj=utm +zone=29 +datum=WGS84 +units=m +no_defs';
> >> xy = ogrproj([0 0], prj)
> xy =
> -13.488743884387196 0
> But with newest version I'm having two problems
> xy =
> -0.000121660050290 -13.488743885487231
> One is that coordinates are not correct (lat should be 0.0)
That one is really odd. It looks like some datum shift would be applied, which
doesn't make sense here since your target SRS uses WGS84 too. Can you run your
code with PROJ_DEBUG=5 and CPL_DEBUG=ON environment variables set ?
For correct results, you should see something like:
OGRCT: proj=pipeline step inv proj=utm zone=29 ellps=WGS84 step
proj=unitconvert xy_in=rad xy_out=deg step proj=axisswap order=2,1 (Inverse of
UTM zone 29N)
> and the other is
> that in this later case it outputs lat,long instead of lon,lat
That one is expected. SetWellKnownGeogCS( "WGS84" ) now returns a SRS with
lat, lon order. You can force "GIS" friendly order by calling
oSRS.SetAxisMappingStrategy(OAMS_TRADITIONAL_GIS_ORDER);
Even
http://www.spatialys.com
