[gdal-dev] Troubles in coord conversions with GDAL+proj6
Even Rouault
even.rouault at spatialys.com
Sun Feb 24 08:02:52 PST 2019
> The ogrproj call should start here
> ERROR 1: PROJ: pj_ellipsoid - final: a=6378137.000 f=1/298.257, errno=0
> ERROR 1: PROJ: pj_ellipsoid - final: ellps=WGS84
> ERROR 1: PROJ: pj_ellipsoid - final: ellps=GRS80
> ERROR 1: PROJ: xy_in unit: Radian
> ERROR 1: PROJ: xy_out unit: Degree
You cut here just at the point were it began to be interesting.
Please report the lines starting with "OGRCT: proj=pipeline "
or provide the full log
http://www.spatialys.com
