[gdal-dev] No like "wgs84"
Joaquim Manuel Freire Luís
jluis at ualg.pt
Sun Feb 24 15:37:00 PST 2019
Ok, makes sense. Thanks
Joaquim
|>-----Original Message-----
|>From: Even Rouault <even.rouault at spatialys.com>
|>Sent: Sunday, February 24, 2019 11:32 PM
|>To: gdal-dev at lists.osgeo.org
|>Cc: Joaquim Manuel Freire Luís <jluis at ualg.pt>
|>Subject: Re: [gdal-dev] No like "wgs84"
|>On dimanche 24 février 2019 23:20:10 CET Joaquim Manuel Freire Luís wrote:
|>> Even, me again.
|>> Don't know if this is on purpose but it breaks previous behavior.
|>> GDAL 2.5dev does not like lower case 'wgs84'
|>Not really "intended", but logical due to the large overhaul done in GDAL 2.5
|>for SRS support (https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn).
|>In previous GDAL version, PROJ string parsing was done by GDAL with likely not
|>really intended case-insensitive string comparison. Now this is done by PROJ
|>itself, and PROJ has always been case sensitive (you can try "proj +proj=merc
|>+datum=wgs84" with older PROJ versions and it will emit that error too)
|>Even
|>Spatialys - Geospatial professional services http://www.spatialys.com
