[gdal-dev] Weird GCPs behavior when flipping an image (left-to-right or upside-down)
Bugbuster
philippe.ghesquiere at airbus.com
Fri Jan 4 08:51:04 PST 2019
Dear all,
I would like to flip a "plain TIFF" (no geolocation information) image with
respect to either lines or columns.
After several tests, I finally found out I have two ways to do it :
1) with a temporary TIFF image
First create a temporary TIFF image with 3 GCPs with gdal_translate
Then create the final "plain TIFF" flipped image with gdalwarp
2) with a temporary VRT image
First create a temporary VRT image with 3 GCPs with gdalbuiltvrt
Both ways give the same results, although the 2nd one is more efficient with
large images.
However, I bumped into some weird results. Here is a small example to
illustrate :
1) I create a TIFF image with 3 GCPs which simulate the identity
transformation :
*gdal_translate -of GTiff -gcp 0 0 0 0 -gcp 100 0 100 0 -gcp 0 100 0 100
TIF_plain.tif TIF_identity_gcp.tif*
2) I warp the intermediate image with the folowing command :
*gdalwarp -of GTiff -co PROFILE=BASELINE TIF_identity_gcp.tif
TIF_identity_warped.tif*
Surprisingly, the final image image TIF_identity_warped.tif is flipped with
respect to lines (upside-down).
Did I miss something ?
Thanks for your hints
Philippe
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
