[gdal-dev] COSMO SkyMed HDF5 driver problem
Gong, Shawn
shawn.gong at mdacorporation.com
Wed Jan 9 11:47:03 PST 2019
Hi list,
I use HDF5 release 1.8.21 in GDAL 2.2.5, and encountered problem with COSMO SkyMed H5:
1) failed to georeference the image,
2) read I and Q as two bands
Previous version of GDAL 1.9 + older HDF5 release 1.8.8 was fine ingesting COSMO SkyMed.
Is this GDAL 2.2.5 issue or HDF5 issue?
Thanks,
Shawn
This electronic correspondence, including any attachments, is intended solely for the use of the intended recipient(s) and may contain legally privileged, proprietary and/or confidential information. If you are not the intended recipient, please immediately notify the sender by reply e-mail and permanently delete all copies of this electronic correspondence and associated attachments. Any use, disclosure, dissemination, distribution or copying of this electronic correspondence and any attachments for any purposes that have not been specifically authorized by the sender is strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190109/7ad8e4db/attachment.html>
