[gdal-dev] How to correctly initialize GDAL library in a multithreaded environment?
Константин Шпурик kostia.shpuryk at gmail.com
Mon Jan 14 03:57:45 PST 2019
Thank you for the quick answer!
The version of GDAL is 2.2.3 and OS is Windows.
I'm using not the latest version, but I've checked the latest code and it
seems like it will still reproduce for Windows for 2.5.0.
Yeah, I've found the ticket, so I'll wait until fixed and will try to
update to latest version.
Thanks,
KS.
On Mon, Jan 14, 2019 at 1:16 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> > I have a multithreaded application that uses GDAL. Generally it works
> fine,
> > but sometimes I have a hang when trying to create transformations from
> > different threads.
> > Seems like race condition occures when initializing static CPLMutex
> > *hConfigMutex located in gdal\port\cpl_conv.cpp file;
> On which operating system and with which GDAL version ?
> With recent enough GDAL versions, and on Linux/Unix, I believe that mutex
> creation should now be thread-safe. But there might still be issues on
> Windows. We should be able to fix that more easily with C++11 mutex now.
> Please file a ticket about that on
> https://github.com/OSGeo/gdal/issues with the above requested details.
> > I was able to fix the issue by calling a function that initializes the
> mutex
> > before calls from different threads(just calling the following code:
> > CPLGetConfigOption("GDAL_DATA", nullptr);) but it doesn't feel right.
> Calling a function like GDALRegisterAll() that involves mutex creation
> before
> creating any thread has been the historical recommandation
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190114/9907e922/attachment.html>
