[gdal-dev] gdalwarp doesn't use the VSIL curl cache ?
Maxime Riché
maxime.riche.insa at gmail.com
Tue Jan 15 08:49:53 PST 2019
I am developing a tile server for COGTiff.
When I open a dataset, the COGTiff metadata are cached in the curl cache.
The beginning of the file is only downloaded when the first tile is served
(using the same tiff). This is as I was expecting.
But when I serve several time the same tile (only this one), I can see that
the pixels are downloaded every time (the metadata are cached). The pixels
are not cached by the VSIL curl cache. These pixels are retrieved with
gdalwarp (using a new dataset everytime).
Is that the expected behavior? Is there a way to cache the pixels (selected
by gdalwarp) ?
It is not a size problem:;
- name: VSI_CACHE_SIZE
value: "268435456"
- name: VSI_CACHE
value: "TRUE"
- name: CPL_VSIL_CURL_CACHE_SIZE
value: "268435456"
Thanks for the clarifications !
Maxime
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
