[gdal-dev] [Non-DoD Source] Re: ogr not reading the prj file
Even Rouault
even.rouault at spatialys.com
Tue Jan 22 09:32:12 PST 2019
On mardi 22 janvier 2019 16:56:56 CET TUELLER, SHAYNE R CIV USAF AFMC 519
SMXS/MXDEC wrote:
> Thank you for the reply.
> I don't think it's a case of wrong identification because the prj file gets
> read in just fine with ogrinfo in gdal 1.11. When I use the gdal 2.3.1 I
> built from source on Windows, it no longer reads the associated prj file
> that is used with the shapefile. Instead, it grabs whatever is defined in
> the "data" folder. I think it may have something to do with the way I built
> the library but I'm not sure.
> Here is the contents of the circles.prj associated with the circles.shp
> file...
> GEOGCS["GCS_WGS_1984", DATUM["D_WGS_1984", SPHERIOD["WGS_1984", 6378137,
> 298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
ok, so I guess ogrinfo -al -so reports
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
This is the expected behaviour. The content of a .prj file is WKT with the
ESRI variant formatting. Newer GDAL versions manage to retrieve the OGC WKT
definition when the ESRI WKT corresponds to a EPSG code.
http://www.spatialys.com
