[gdal-dev] OGRSpatialReference class
TUELLER, SHAYNE R CIV USAF AFMC 519 SMXS/MXDEC
shayne.tueller at us.af.mil
Tue Jan 22 12:45:24 PST 2019
Hello,
In my app, I'm using the OGRSpatialReference class to get the SRS info for a ESRI shapefile by doing the following...
OGRSpatialReference* ogrSRS = layer->GetSpatialRef();
Is there a way to extract the user visible name (the one not used as a key) for the geographic coordinate system as defined in the prj file associated with the shapefile instead?
Thanks.
Shayne
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190122/433af3ad/attachment.html>
