[gdal-dev] RFC 73 (aka gdalsrsbarn) available for review
Even Rouault
even.rouault at spatialys.com
Tue Jan 22 13:30:55 PST 2019
Hi Markus,
Thanks for your feedback
> Regarding WKT2, a remark from a GRASS GIS developer being a user of
> GDAL/PROJ:
> I understand that WKT2 is long overdue and thus should be pushed as much
> and as early as possible. Otherwise it would take a long time and a rather
> long and painful transition process to switch to WKT2. My suggestion is to
> try to keep the painful transition process as short as possible and switch
> to WKT2 ASAP. People like to stick to what they have and what they know, so
> if something better is available, some convincing is needed.
So you would be in favor of making OSRExportToWkt() default to WKT2 ?
(probably WKT2:2018 while we are at it ? Not just the output of gdalinfo /
ogrinfo utilities.
I was shy in doing so, because it will likely require updating a good deal of
GDAL autotests, but oh well...
What annoys me a bit more is the case of XML files like GDAL VRT, OGR VRT or
.aux.xml that contains serialized SRS and that I wanted to be backward
compatible with older GDAL versions as much as possible.
> Backwards compatibility wrt reading WKT1 needs to be maintained because
> already existing datasets must still be readable.
Yes this is of course done. Export to older WKT versions will likely still be
needed for some formats too
> Regarding the BBOX, it should be made clear that the reported extents are a
> suggestion, not a limitation.
The semantics is a bit fuzzy. The WKT standard mentions "Extent describes the
spatial and/or temporal applicability of a CRS, datum, datum ensemble,
coordinate operation or Bound CRS". For a CRS, you can go beyond depending on
the numeric stability of the implementation of the projection method (in case
of a projected CRS). For a coordinate operation, if it involves a grid, the
BBOX should be interpreted in a rather strict way (that's what PROJ master
does internally when computing the most appropriate coordinate transformation
given all the constraints it is given)
Even
http://www.spatialys.com
