[gdal-dev] ubuntu_1804
Craig de Stigter
craig.destigter at koordinates.com
Thu Jan 24 22:02:03 PST 2019
I didnt write it but I had to fiddle with the build scripts quite a bit for
the pytest refactor. Travis only supports Trusty (recently added Xenial,
though I don't think GDAL is using that yet either.)
The ubuntu_1804 job builds an entire Ubuntu 18.04 install in a chroot
(using debootstrap) inside the travis Trusty environment. It's not terribly
elegant but gets the job done. So the kernel is the travis trusty kernel
but the userland is ubuntu 18.04.
Hope that clarifies things.
Craig de Stigter
On Fri, 25 Jan 2019, 12:34 Alan Stewart, <astewart at terragotech.com> wrote:
> The raw log for the ubuntu_1804 Travis job (specifically #15454.1) seems
> to indicate that the OS is Ubuntu 14.04 . From the build name I assumed it
> would be Ubuntu 18.04?
> Alan Stewart
> Senior Software Engineer
> *Terra**Go **Technologies*
> 3200 Windy Hill Road, Suite 1550W
> Atlanta, GA 30339 USA
> O. +1 678.391.9615
> www.terragotech.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190125/9afee13c/attachment.html>
