[gdal-dev] RFC 73 (aka gdalsrsbarn) available for review
Even Rouault
even.rouault at spatialys.com
Mon Jan 28 05:02:43 PST 2019
Darafei,
A Geographic 3D CRS is a CRS, that is based on a geodetic reference frame
(geodetic datum), and has a coordinate system with 3 axis: latitude, longitude
and ellipsoidal height. For example EPSG:4979 is the code for the Geographic
3D CRS corresponding to "WGS 84" (EPSG:4326 is the corresponding Geographic 2D
CRS).
This is what is described in OGC 08-015r2 "Abstract Specification Topic 2
Spatial referencing by coordinates"
https://portal.opengeospatial.org/files/?artifact_id=39049
in "B.1.2.1 Principal subtypes of coordinate reference system" a) under the
older term of "geodetic CRS using 3D ellipsoidal coodinates".
The newer revision of this document (expected for public release in the next
weeks/months) will use the term "geographic 3D CRS".
Even
> Hello,
> I would like to learn more about geographic 3D CRS. There is ad-hoc
> solution in PostGIS ("geography") to handle 3D geographies, and I would
> like to learn about alternative ways of signaling that calculations are to
> be done on curved surface.
> On Wed, Jan 9, 2019 at 6:23 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Hi,
> > RFC 73 "Integration of PROJ6 for WKT2, late binding capabilities,
> > time-support
> > and unified CRS database" is available for your review at:
> > https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn
> > The proposed implementation is at:
> > https://github.com/OSGeo/gdal/pull/1185
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
