[gdal-dev] setting a spatial filter on a postgis layer gives wrong results
Even Rouault
even.rouault at spatialys.com
Fri Jul 5 01:33:26 PDT 2019
On vendredi 5 juillet 2019 10:12:41 CEST Landry Breuil wrote:
> Hi,
> initially saw this with gdal 2.2.3 on debian, and confirmed the
> behaviour is the same with gdal 3.0 on openbsd.
> I'm doing a spatial join between an union of geometries filtered from a
> geopackage and a tileindex layer stored in postgis, and the spatial
> filter set on the postgis layer behaves weird, the provided result is as
> if the bbox of the spatial filter/geometry was used, instead of the
> filter itself.
This indeed exactly this. The PG driver implements spatial filtering only
based on the envelope of the filter geometry, whereas the MEM driver uses the
full geometry
Quoting
https://gdal.org/api/
ogrlayer_cpp.html#_CPPv4N8OGRLayer16SetSpatialFilterEP11OGRGeometry
Currently this test is may be inaccurately implemented, but it is guaranteed
that all features whose envelope (as returned by OGRGeometry::getEnvelope())
overlaps the envelope of the spatial filter will be returned. This can result
in more shapes being returned that should strictly be the case.
I guess the PG driver should be fixed. This is probably just an historical
artifact.
Even
http://www.spatialys.com
