[gdal-dev] GDAL & OGDI
tolga ergenekonlu tergenekonlu at yahoo.com
Tue Jul 9 04:57:26 PDT 2019
I want to built gdal2.2.4 and ogdi 3.1.6 together. I am using Visual Studio 2010. I copied both of those directories in D:\folder. I execute the following command in folder "D:\gdal-2.2.4" where gdal is copied:
   -  nmake /f makefile.vc
But the build gets error. The nmake.opt file and the error I get are attached. Can you help me about how to build GDAL with OGDI?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190709/5e16e370/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190709/5e16e370/attachment-0001.txt>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190709/5e16e370/attachment-0001.obj>
