[gdal-dev] 'HOST_FILLORDER': macro redefinition
Even Rouault
even.rouault at spatialys.com
Mon Jul 15 03:23:01 PDT 2019
> If it were redefining to the same value, that would be one thing, but since
> it is redefining to another value, it makes you wonder 1) why is it coming
> in differently, and 2) which value should it be?
Paul, overall this doesn't seem critical as the only real use of
HOST_FILLORDER in all GDAL, libtiff and libgeotiff code bases in in libtiff
TIFFOpen() function when the esoteric 'H' open flag is used, and that one is
likely rarely used (not used by GDAL typically). So you could just #undef
HOST_FILLORDER between the 2 #include to silence the warning.
Tamas, how is tiffconf.h in gisinternals produced, which has this unexpected
#define HOST_FILLORDER FILLORDER_MSB2LSB (should be LSB2MSB for Intel
platforms) ? Is this the result of cmake ? I guess so, as it doesn't seem to
be in sync with the tiffconf.vc.h that is also provided and used by nmake
builds. That would mean that there's an issue in the CMake configuration step
with VS builds:
https://gitlab.com/libtiff/libtiff/blob/master/CMakeLists.txt#L394
Actually, I just found a CI with CMake + Windows at
https://ci.appveyor.com/project/rleigh-codelibre/libtiff-didfs/builds/
25846668/job/ory5w098j8wcij9x
where I can see:
[00:02:58] -- CMAKE_HOST_SYSTEM_PROCESSOR set to AMD64
[00:02:58] -- HOST_FILLORDER set to FILLORDER_MSB2LSB
So this seems to be a case sensitivity issue when comparing AMD64 vs amd64.
I've just submitted
https://gitlab.com/libtiff/libtiff/merge_requests/87
to fix this.
Even
http://www.spatialys.com
