[gdal-dev] Python RasterizeLayer and gdal_rasterize
Ivan Lucena
ivan.lucena at outlook.com
Wed Jul 24 15:19:28 PDT 2019
Thanks Mike,
I found the problem.
When I call CreateLayer() I am passing the SRS but if I try to print it just before calling RasterizeLayer(), it is not there.
I tried to call FlushCache() and SyncToDisk() but the only thing that solve the problem is to close the dataset and open it again.
geom_ds = ogr.GetDriverByName('GEOJSON').CreateDataSource('E:\TMP\MEMORY_%s.JSON' % name)
geom_lyr = geom_ds.CreateLayer('MEMORY_LAYER', geom_type=ogr.wkbPolygon, srs=ref_srs)
geom_feat = ogr.Feature(geom_lyr.GetLayerDefn())
geom_feat.SetGeometry(geom)
geom_lyr.CreateFeature(geom_feat)
geom_ds.FlushCache() # That doesn't
geom_ds.SyncToDisk() # help
mem_ds = gdal.GetDriverByName('GTIFF').Create('E:\TMP\MEMORY_%s.TIF' % name, xcount, ycount, 1, gdal.GDT_Byte)
mem_ds.SetGeoTransform((xmin, xResolut, 0, ymax, 0, yResolut,))
mem_ds.SetProjection(ref_ds.GetProjectionRef())
mem_ds.FlushCache()
print(geom_lyr.GetSpatialRef()) # None!!
# That's the solution: close and open the dataset again
geom_ds = None
geom_ds = ogr.Open('E:\TMP\MEMORY_%s_GEOM.JSON' % name)
geom_lyr = geom_ds.GetLayerByName('MEMORY_LAYER')
# todo: how can I do that in memory?
print(geom_lyr.GetSpatialRef()) # Good!!
err = gdal.RasterizeLayer(mem_ds, [1], geom_lyr, burn_values=[1])
if err != 0:
print(err)
Even, does it look like a bug to you? A GEOJSON driver bug maybe. I probably did something like that once in a raster driver, wait for the closing of the file to update the SRS.
Thanks,
Ivan
Sent: Wednesday, July 24, 2019 4:40 PM
To: Ivan Lucena <ivan.lucena at outlook.com>
Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Python RasterizeLayer and gdal_rasterize
On Thu, 25 Jul 2019 at 01:19, Ivan Lucena <ivan.lucena at outlook.com> wrote:
Check your value for yResolut, as it should be negative. In my
experience, a raster full of zeros is when the geometry is outside the
raster window, so be sure to manually check the raster and vector
geometries in (e.g.) QGIS. Lastly, to properly close the file, you
only need to dereference the object:
mem_ds = None
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190724/9b7d6027/attachment-0001.html>
