[gdal-dev] Motion: adopt RFC 75: Multidimensional array
Even Rouault
even.rouault at spatialys.com
Fri Jul 26 07:34:52 PDT 2019
On jeudi 25 juillet 2019 19:57:44 CEST Joe Lee wrote:
> Unsupported number of dimensions
Ah ok, when exporting to GeoTIFF or a "classic" 2D driver, the
multidimensional-to-classic bridge currently checks that the array is a 2D
one. Here you reduced it to a 1D-slice, hence it rejects it. The bridge could
probably be made a bit more flexible by accepting 1D arrays as well. If you
export to netCDF, this should work fine though (as this won't go through the
bridge, but use directly multidimensional netCDF output capabilities)
Even
http://www.spatialys.com
