[gdal-dev] GMLAS tries to read spatialreference.org through http
Even Rouault even.rouault at spatialys.com
Tue Jun 4 01:02:54 PDT 2019
On mardi 4 juin 2019 06:15:54 CEST Rahkonen Jukka (MML) wrote:
> I am getting lots of warning like this from the GMLAS driver:
> HTTP: Fetch(http://spatialreference.org/ref/epsg/28992/)
> HTTP: These HTTP headers were set: Accept: application/x-ogcwkt
> ERROR 1: Connection timed out after 10563 milliseconds
> Warning 1: Reprojection fom http://spatialreference.org/ref/epsg/28992/ to >
> urn:x-ogc:def:crs:EPSG:28992 failed
> I guess that the code should be changed to try https instead.
Doesn't look like it is needed. The following works:
gdalsrsinfo http://spatialreference.org/ref/epsg/28992/
and does the redirection to https
Maybe you hit a temporary issue with the server ?
> The typo "fom" comes also from the driver.
Fixed
http://www.spatialys.com
