[gdal-dev] Issues installing gdal from source code
Andrew Bell
andrew.bell.ia at gmail.com
Wed Jun 5 04:50:29 PDT 2019
Perhaps I'm missing something, but I'm seeing no throw specifications on my
2.1 source. I'm guessing you're finding header files from a version that
is different from the version you're trying to compile. I'd search your
system for "cpl_string.h" and compare with the include directories used
during compilation.
On Wed, Jun 5, 2019 at 6:30 AM Jorge Martin <jormarfe at gmail.com> wrote:
> Hello,
> Trying to compile gdal 2.1.1 we are getting the following error:
> ./configure --with-libtiff=/opt/cots/tiff-4.0.0
> --with-geotiff=/opt/cots/geotiff-1.4.0 --prefix=/opt/cots/gdal_v2
> make
> (cd port; make)
> make[1]: Entering directory `/data2/mvit/gdal-2.1.1/port'
> cpl_string.cpp: In function 'int CPLVASPrintf(char**, const char*,
> __va_list_tag*)':
> cpl_string.cpp:1034: error: declaration of 'int CPLVASPrintf(char**, const
> char*, __va_list_tag*)' throws different exceptions
> cpl_string.h:215: error: from previous declaration 'int
> CPLVASPrintf(char**, const char*, __va_list_tag*) throw ()'
> cpl_string.cpp: In function 'int CPLvsnprintf(char*, size_t, const char*,
> __va_list_tag*)':
> cpl_string.cpp:1124: error: declaration of 'int CPLvsnprintf(char*,
> size_t, const char*, __va_list_tag*)' throws different exceptions
> cpl_string.h:195: error: from previous declaration 'int
> CPLvsnprintf(char*, size_t, const char*, __va_list_tag*) throw ()'
> cpl_string.cpp: In function 'int CPLsnprintf(char*, size_t, const char*,
> cpl_string.cpp:1305: error: declaration of 'int CPLsnprintf(char*, size_t,
> const char*, ...)' throws different exceptions
> cpl_string.h:197: error: from previous declaration 'int CPLsnprintf(char*,
> size_t, const char*, ...) throw ()'
> our system is Red Hat Enterprise Linux Server release 5.1 (Tikanga) and we
> have installed previous version of gdal in the machine.
> We also have tried to install other versions such as 2.2.1, 2.2.2 and
> 2.2.3 and we got the same error. The vesion that we have installed is
> 1.8.1.
> Regards,
> Jorge
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190605/dcabfea3/attachment.html>
