[gdal-dev] gdalinfo's and rasterio's reading problem in LUSTRE FS with NetCDF file (ubuntu:bionic)
Even Rouault
even.rouault at spatialys.com
Wed Jun 5 14:49:34 PDT 2019
On mercredi 5 juin 2019 13:44:07 CEST Erick Palacios Moreno wrote:
> Hi everyone,
> My team and I have been facing some problems when reading netcdf files in
> `LUSTRE` filesystem with `ncdump` tool regarding an HDF5 1.10.1 issue in
> `ubuntu:bionic` (see for example:
> https://github.com/ALPSCore/ALPSCore/issues/410)
> We made a workaround by installing `netcdf-bin` using repositories of
> `ubuntu:xenial` in `bionic`. Although `ncdump` have successfully read the
> netcdf file, we couldn't fix it (sort of...) for `gdalinfo` and `rasterio`
> for example:
> this works:
> ncdump /LUSTRE/MADMEX/dir_test_mount/madmex_003_37_-32_1996-01-01.nc|head -n
> 20
> gdalinfo /LUSTRE/MADMEX/dir_test_mount/madmex_003_37_-32_1996-01-01.nc |head
> -n 20
> gdalinfo -sd 1 /LUSTRE/MADMEX/dir_test_mount/madmex_003_37_-32_1996-01-01.nc
> |head -n 20
> but this neither of next lines work:
> gdalinfo
> netcdf:/LUSTRE/MADMEX/dir_test_mount/madmex_003_37_-32_1996-01-01.nc:blue_m
> ean
That one is weird, I mean that 'gdalinfo -sd 1 ...' works, but not 'gdalinfo
netcdf:....', since the former internally invokes the later, but with the
difference of an extra GDALOpen()/GDALClose().
I think you've already found the root cause of all this, that its that HDF5
1.10 doesn't play well with LUSTRE, which causes those kind of weird/random
failures. Nothing that GDAL can do about. So your best option is to build GDAL
and libnetcdf against a libhdf5 version that plays well with LUSTRE, or copy
locally the files.
Even
http://www.spatialys.com
