[gdal-dev] [COG] Upcoming Cloud Optimized Geotiff (COG) related enhancements
Vincent Sarago vincent.sarago at gmail.com
Tue Jun 11 07:48:22 PDT 2019
Thanks Even,
Just a quick note. By reading the docs it seems the overviews will be created by default except if OVERVIEWS=FORCE_USE_EXISTING is set and if the input file doesn’t have overviews. The specs make overviews optional thus the OVERVIEWS option usage seems a bit odd.
TBH, I’m 100% with creating overviews by default and I think they should not be optional, but users that don’t want overviews might found the usage a bit complicated.
Vincent
> Le 11 juin 2019 à 10:36, Even Rouault <even.rouault at spatialys.com> a écrit :
> Hi,
> the last bits (points 1, 2 and 3) are now available in GDAL master.
> Doc at https://gdal.org/drivers/raster/cog.html
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> COG mailing list
> COG at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/cog
