[gdal-dev] [COG] Upcoming Cloud Optimized Geotiff (COG) related enhancements
Vincent Sarago
vincent.sarago at gmail.com
Tue Jun 11 08:21:31 PDT 2019
Thanks Even
> Le 11 juin 2019 à 11:20, Even Rouault <even.rouault at spatialys.com> a écrit :
> Vincent,
>> Just a quick note. By reading the docs it seems the overviews will be
>> created by default except if OVERVIEWS=FORCE_USE_EXISTING is set and if the
>> input file doesn’t have overviews. The specs make overviews optional thus
>> the OVERVIEWS option usage seems a bit odd.
> Agreed that's a bit convoluted. I've added support for OVERVIEWS=NONE to
> decrease the quantity of caffeine needed to generate a COG without overviews
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
