[gdal-dev] Convert WGS84 geodetic coordinate to local ENU(local Cartesian coordinates coordinate system)
Kristian Evers kreve at sdfe.dk
Wed Jun 12 02:23:18 PDT 2019
Here's the relevant PROJ issue should someone want to give this a go
https://github.com/OSGeo/PROJ/issues/500
/Kristian
-----Oprindelig meddelelse-----
Fra: gdal-dev <gdal-dev-bounces at lists.osgeo.org> På vegne af Even Rouault
Sendt: 12. juni 2019 11:00
Til: gdal-dev at lists.osgeo.org
Cc: Changhai Chen <cchhnhk at gmail.com>
Emne: Re: [gdal-dev] Convert WGS84 geodetic coordinate to local ENU(local Cartesian coordinates coordinate system)
On mercredi 12 juin 2019 11:42:12 CEST Changhai Chen wrote:
> Hello. Is there any method in GDAL that can convert WGS84 geodetic
> coordinate to local ENU(local tangent plane)?
> First: GDAL can transform point coordinate from WGS84 geodetic  coordinate
> system to WGS84 XYZ (or ECEF ).
> Second: but WGS84 XYZ (or ECEF ) to local ENU can not be transformed. I can
> fix it by using another tool, but it will be better if GDAL have this
> convesion.
That should be implemented as a new coordinate operation in PROJ. There's a
description for this method in the IOGP Guidance note 7.2.
http://www.epsg.org/Portals/0/373-07-02.pdf , page 97, 	"2.2.2 Geocentric/
topocentric conversions"
Contributions welcome
Even
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
