[gdal-dev] Question on python gdal.Rasterize()
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Fri Jun 14 10:58:48 PDT 2019
Hi all,
My goal is to take satellite track data and create a gtiff file using
Python.
The satellite data is in a NetCDF file, which I can read in Python and
has variables lat, lon, ssha. There are a continue stream of the NetCDF
data over time so I plan to just keep loading them as they become available.
My thought is to take adjacent track points as a LineStringZ and burn
them into the image overwriting any existing data. This will keep the
gtiff up to date with the most current data for any given area.
Maybe there is a better way to do this? suggestions welcome.
I was looking at gdal.RasterizeOptions() and gdal.Rasterize() and my
thought was that I could create feature with geom like (lon, lat, ssha)
and then rasterize that into the image using the option "useZ=True" but
this seems to imply that I need to have an ogr source for the vector
data. It would be much more convenient to be able to just pass features
from python to the Rasterize() function.
I see callback and callback_data in the options can these be used for
that? How?
Rasterize(destNameOrDestDS, srcDS, **kwargs)
I can open the gtiff file and then pass the handle of that to
destNameOrDestDS.
Can a create an in memory srcDS that I've loaded with the track
segments. The NetCDF files have about 5-6000 track points in them so an
eqivalent number of LineStringZ features.
Is there an example of something similar you can link me to.
Thanks,
-Steve
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
