[gdal-dev] Failure to convert to Airy
Joaquim Manuel Freire Luís jluis at ualg.pt
Mon Jun 17 12:45:34 PDT 2019
I used the gdaltranslate example because I knew that it would much simpler for you to test but, as I said first, this issue was raised by a call to GDAL from GMT.
Looked again into it and what happens is that the gmt_OGRCoordinateTransformation() call runs fine when
pSrcSRS = "+proj=latlong +datum=WGS84"
pDstSRS = "+proj=airy +ellps=WGS84 +units=m"
but raise the error when I change the order of the source and target (i.e. create the inverse mapping)
pSrcSRS = "+proj=airy +ellps=WGS84 +units=m"
pDstSRS = "+proj=latlong +datum=WGS84"
In this case, it even raises an exception in VS debugger at line #63
		CPLFree(pSrcSRS);		CPLFree(pDstSRS);
|>On lundi 17 juin 2019 17:14:21 CEST Joaquim Manuel Freire Luís wrote:
|>> Well, I call it via GMT but that test is in GMT for a while and it
|>> used to pass.
|>> Anyway, I'll have to investigate this further because I rebuilt GDAL
|>> and now the gdaltransform works, but when I call it from GMT is still fails.
|>> The code is
|>> https://github.com/GenericMappingTools/gmt/blob/master/src/gmt_ogrproj
|>> .c#L27
|>gmt_OGRCoordinateTransformation(() isn't actually equivalent to
|>gdaltransform, since it only creates the forward transformer.
|>So that should, normally, work with both GDAL < 3 or GDAL >= 3 when going
|>from longlat to airy.
|>Spatialys - Geospatial professional services http://www.spatialys.com
