[gdal-dev] Failure to convert to Airy
Joaquim Manuel Freire Luís jluis at ualg.pt
Mon Jun 17 13:14:23 PDT 2019
Right. I changed the signature and removed the CPLFree() and now in GMT it also ... half works. The middle warnings are print from GMT but the other come from GDAL and are like those you suppressed in your gdaltransform commit.
So, I should try to catch this type of cases where one can do the direct transform but not the reverse. Any place where I can search what other then Airy have the same issue?
echo 4.897 52.371 | mapproject -J+proj=airy
ERROR 1: PROJ: proj_create: Error -50: malformed pipeline
ERROR 6: Cannot find coordinate operations from `PROJCRS["unknown",BASEGEOGCRS["unknown",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]],ID["EPSG",6326]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8901]]],CONVERSION["unknown",METHOD["PROJ airy"]],CS[Cartesian,2],AXIS["(E)",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["(N)",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]' to `GEOGCRS["unknown",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]],ID["EPSG",6326]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8901]],CS[ellipsoidal,2],AXIS["longitude",east,ORDER[1],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]],AXIS["latitude",north,ORDER[2],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]]]'
mapproject [ERROR]: Failed to create coordinate transformation between the following
coordinate systems. This may be because they are not transformable,
or because projection services (PROJ.4 DLL/.so) could not be loaded.
mapproject [ERROR]: Source:
PROJCS["unknown",
    GEOGCS["unknown",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
            AUTHORITY["EPSG","8901"]],
            AUTHORITY["EPSG","9122"]]],
    PROJECTION["custom_proj4"],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    EXTENSION["PROJ4","+proj=airy +datum=WGS84 +wktext +no_defs"]]
GEOGCS["unknown",
    DATUM["WGS_1984",
        AUTHORITY["EPSG","9122"]],
    AXIS["Longitude",EAST],
    AXIS["Latitude",NORTH]]
ERROR 10: Pointer 'hTransform' is NULL in 'OCTTransform'.
328249.003313   4987937.10145
