[gdal-dev] How do I get lat long extents from this Ogrinfo output on a .shp?
Dante, Paul
paul.dante at ubc.ca
Thu Jun 20 13:26:47 PDT 2019
I ran ogrinfo on a shape file and got output. How do I convert the extent listed below into lat long coordinates? It looks like the units are meters, but I’m not sure how that will translate to lat long for creating a bounding box:
INFO: Open of `OldStreamsPolyline.shp'
using driver `ESRI Shapefile' successful.
Layer name: OldStreamsPolyline
Metadata:
DBF_DATE_LAST_UPDATE=2011-02-17
Geometry: Line String
Feature Count: 179
Extent: (482246.857278, 5449862.717375) - (498293.801839, 5462019.990072)
Layer SRS WKT:
PROJCS["NAD83 / UTM zone 10N",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4269"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-123],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","26910"]]
Region: String (2.0)
Type: String (50.0)
Paul Dante
Software Developer - Geodisy
Walter C. Koerner Library | UBC Library
The University of British Columbia | Vancouver Campus
219-1958 Main Mall | Vancouver BC | V6T 1Z2 Canada
Phone 604 827 5129
paul.dante at ubc.ca<mailto:paul.dante at ubc.ca>
UBC Vancouver is located on the traditional, ancestral, unceded territory of the xʷməθkʷəy̓əm (Musqueam) people
[cid:image001.png at 01D42428.A8255E20]
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190620/bad8e2a8/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190620/bad8e2a8/attachment.png>
