[gdal-dev] How do I get lat long extents from this Ogrinfo output on a .shp?
Dante, Paul paul.dante at ubc.ca
Thu Jun 20 14:20:05 PDT 2019
Steve,
Thanks, that works wonderfully!
I figured the other data in the file was UTM as well, but I'm only using the extents in my program, which is why I focused on them.
+Paul
Paul Dante
Software Developer - Geodisy
Walter C. Koerner Library | UBC Library
The University of British Columbia | Vancouver Campus
219-1958 Main Mall | Vancouver BC | V6T 1Z2 Canada
Phone 604 827 5129
UBC Vancouver is located on the traditional, ancestral, unceded territory of the xʷməθkʷəy̓əm (Musqueam) people
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Stephen Woodbridge
Sent: Thursday, June 20, 2019 1:33 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] How do I get lat long extents from this Ogrinfo output on a .shp?
Hi Paul,
Its not just the extents but all the data in the file is in a UTM projection. You can reproject the file to WGS84 and then ogrinfo will report in long-lat.
ogr2ogr -t_srs EPSG:4326 OldStreamsPolyline-wgs84.shp OldStreamsPolyline.shp ogrinfo -so OldStreamsPolyline-wgs84.shp OldStreamsPolyline-wgs84
-Steve W
On 6/20/2019 4:26 PM, Dante, Paul wrote:
> I ran ogrinfo on a shape file and got output. How do I convert the
> extent listed below into lat long coordinates? It looks like the units
> are meters, but I’m not sure how that will translate to lat long for
> creating a bounding box:
> INFO: Open of `OldStreamsPolyline.shp'
>       using driver `ESRI Shapefile' successful.
> Layer name: OldStreamsPolyline
> Metadata:
> DBF_DATE_LAST_UPDATE=2011-02-17
> Geometry: Line String
> Feature Count: 179
> Extent: (482246.857278, 5449862.717375) - (498293.801839,
> 5462019.990072)
> Layer SRS WKT:
> PROJCS["NAD83 / UTM zone 10N",
> GEOGCS["NAD83",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6269"]],
> PRIMEM["Greenwich",0,
>   AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4269"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-123],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","26910"]]
> Region: String (2.0)
> Type: String (50.0)
> Paul Dante
> Phone 604 827 5129
> paul.dante at ubc.ca <mailto:paul.dante at ubc.ca>__
> cid:image001.png at 01D42428.A8255E20
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
