[gdal-dev] kml file with line length too long
Joaquim Manuel Freire Luís jluis at ualg.pt
Thu Jun 27 13:17:22 PDT 2019
But not for me with a master (~1-2 weeks old) GDAL
ogr2ogr -f "ESRI Shapefile" test.shp IS2_RGT_0002_cycle4_28-Jun-2019.kml
ERROR 1: Failed to create file test.shp\RGT 2 DOY-179 28-Jun-2019 04:55:18.shp: No error
ERROR 1: Terminating translation prematurely after failed
translation of layer RGT 2 DOY-179 28-Jun-2019 04:55:18 (use -skipfailures to skip errors)
C:\v>ogr2ogr --version
GDAL 3.1.0dev, released 2019/99/99
|>-----Original Message-----
|>From: Even Rouault <even.rouault at spatialys.com>
|>Sent: Thursday, June 27, 2019 9:08 PM
|>To: gdal-dev at lists.osgeo.org
|>Cc: Joaquim Manuel Freire Luís <jluis at ualg.pt>
|>Subject: Re: [gdal-dev] kml file with line length too long
|>On jeudi 27 juin 2019 18:47:12 CEST Joaquim Manuel Freire Luís wrote:
|>> Even
|>> You may be interested in this GMT issue
|>> https://github.com/GenericMappingTools/gmt/issues/1012
|>> As mentioned there, ogr2ogr fails for that file too. The diagnostic:
|>> line length too long.
|>Hum, ogr2ogr works fine here (2.4 and master on Linux, test with a 2.1.2 on a
|>gisinternals Windows build as well). Just warnings about field name truncation.
|>Even
|>Spatialys - Geospatial professional services http://www.spatialys.com
