[gdal-dev] UnionCascaded operation failed
Ahmet Temiz
ahmettemiz88 at gmail.com
Sun Jun 30 22:55:37 PDT 2019
Ok, thanks.
On Mon, Jul 1, 2019 at 8:39 AM Casper Børgesen <caboe at sdfe.dk> wrote:
> A very quick guess would be that you have changed the polyCollect type
> from a geometry type to a list of geometries. I don’t think the list of
> geometries has a UnionCascaded method. I would probably go for a
> polyCollect geometry type of MultiPolygon instead of the list/vector, that
> way you should be able to run the UnionCascaded method.
> /Casper
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *On Behalf Of *Ahmet
> Temiz
> *Sent:* 29. juni 2019 19:47
> *To:* gdal-dev <gdal-dev at lists.osgeo.org>
> *Subject:* [gdal-dev] UnionCascaded operation failed
> Hi,
> Using C++ I try to buffers from LineStrings,Then I want to union the
> resulting polygons with UnionCascaded.
> But at UnionCascaded operation failed with:
> "error: ‘class std::vector<OGRPolygon*>’ has no member named
> ‘UnionCascaded’
> OGRGeometry *result=polyCollect.UnionCascaded();
> Can you tell me what I am doing wrong?
> here is the related code fragment:
> std::vector<OGRPolygon * > polyCollect ;
> //OGRGeometryCollection *polyCollect ;
> while( (poFeature = poLayer->GetNextFeature()) != NULL )
> OGRGeometry *poGeometry = poFeature->GetGeometryRef();
> if( poGeometry != NULL
> && wkbFlatten(poGeometry->getGeometryType()) ==
> wkbLineString )
> OGRLineString *poLine = (OGRLineString *) poGeometry;
> OGRGeometry *bufGeometry = poLine->Buffer(100,30);
> OGRPolygon *bufPoly= static_cast<OGRPolygon *> (bufGeometry) ;
> printf( "%s \n", bufPoly->getGeometryName());
> //polyCollect->addGeometryDirectly (bufPoly );
> polyCollect.push_back(bufPoly );
> else
> printf( "no point geometry\n" );
> OGRFeature::DestroyFeature( poFeature );
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
> ________________________
> Ahmet Temiz
> Geological Eng.
> Information Systems - GIS Group
> Disaster and Emergency Management
> of Presidency
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190701/f5539694/attachment.html>
