[gdal-dev] OGDI 4.0.0RC1 ready for testing
Even Rouault
even.rouault at spatialys.com
Fri Mar 1 05:33:55 PST 2019
I've prepared a OGDI 4.0.0 release candidate.
Download links:
https://freefr.dl.sourceforge.net/project/ogdi/ogdi/4.0.0RC1/ogdi-4.0.0RC1.tar.gz
https://freefr.dl.sourceforge.net/project/ogdi/ogdi/4.0.0RC1/ogdi-4.0.0RC1.zip
The news are
4.0.0
o Remove PROJ.4 dependency, functionality and related API
With PROJ 6 being released and removing completely projects.h old API,
a major upgrade would have been needed. I'd rather choose to completely
cut off PROJ related functionality from OGDI.
For the VRF case, projection support can be done through the GDAL/OGR
OGDI driver.
The dtusa and dtcanada drivers are removed.
The following functions are removed from ecs_util.h:
cln_SetServerProjection
cln_SetClientProjection
cln_ProjInit
cln_CompareProjections
cln_ConvRegion
cln_ConvTtoS
cln_ConvStoT
cln_ChangeProjection
cln_ChangeProjectionArea
cln_ChangeProjectionLine
cln_ChangeProjectionPoint
cln_ChangeProjectionMatrix
cln_ChangeProjectionImage
cln_ChangeProjectionText
ecs_distance_meters
o Update server version to 4.0 to reflect removal of SetServerProjection
capability
o Build: add -fPIC when required
o Rename aclocal.m4 to acinclude.m4 and apply stricter quoting
o Respect LDFLAGS provided to ./configure
o Fall back to libtirpc if libc does not provide rpc/rpc.h
o Don't hardcode compiler to fix cross compilation.
I've verified it works fine with GDAL/OGR OGDI driver with the VRF OGDI driver of both
GDAL 2.4 and GDAL master, since GDAL does not use the now removed OGDI PROJ capabilities
Sourceforge CVS being now read-only, upstream development is now definitely at
https://github.com/libogdi/ogdi
I'll promote this RC to final if there are no serious issues reported.
Even
http://www.spatialys.com
