[gdal-dev] convert india-latest.osm to india-latest.tab
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Thu Mar 7 05:54:23 PST 2019
MapInfo driver can write only one layer into one tab. However, it can write
several layers as separate tab files into a directory as documented in
https://www.gdal.org/drv_mitab.html.
Write your command as
ogr2ogr -f "MapInfo File" -skipfailures -progress bhutan
bhutan-latest.osm.pbf
and you will get a directory with MapInfo files
lines.tab
multilinestrings.tab
multipolygons.tab
other_relations.tab
points.tab
-Jukka Rahkonen-
mick howe-2 wrote
> been experimenting and worked this much out
> *[mick at cave OSMIndia]$ ogr2ogr -f "MapInfo File" -skipfailures -progress
> bhutan.tab bhutan-latest.osm.pbf*
> *0...10...20...30...40...50...60...70...80...90...100 - done.*
> ERROR 1: Layer 'lines' does not already exist in the output dataset, and
> cannot be created by the output driver.
> ERROR 1: Layer 'multilinestrings' does not already exist in the output
> dataset, and cannot be created by the output driver.
> ERROR 1: Layer 'multipolygons' does not already exist in the output
> ERROR 1: Layer 'other_relations' does not already exist in the output
> *[mick at cave OSMIndia]$ *
> from this I got some points but nothing
> mick in glen innes
> On Thu, 7 Mar 2019 at 01:09, mick howe <
> mickhowe292@
> > wrote:
>> Been struggling with this for a month with this. I'm trying to convert an
>> open street map to MapInfo, dropping some fields as I go, if possible.
>> I believe ogr2ogr is the appropriate tool and can see what looks like
>> part
>> of what I want in https://gdal.org/1.11/ogr2ogr.html but it is too
>> spartan for me too find the complete answer there.
>> Is there some fuller documentation I haven't found or someone willing to
>> guide me through this process
>> mick in glen innes
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
