[gdal-dev] OGDI 4.0.0 is released
Even Rouault even.rouault at spatialys.com
Mon Mar 11 04:30:10 PDT 2019
OGDI 4.0.0 RC1 is promoted to final 4.0.0 release.
Download links:
https://freefr.dl.sourceforge.net/project/ogdi/ogdi/4.0.0/ogdi-4.0.0.tar.gz
https://freefr.dl.sourceforge.net/project/ogdi/ogdi/4.0.0/ogdi-4.0.0.zip
Even
On vendredi 1 mars 2019 14:33:55 CET Even Rouault even.rouault at spatialys.com
[ogdidev] wrote:
> Hi,
> I've prepared a OGDI 4.0.0 release candidate.
> Download links:
> https://freefr.dl.sourceforge.net/project/ogdi/ogdi/4.0.0RC1/ogdi-4.0.0RC1.t
> ar.gz
> zip
> The news are
> 4.0.0
>  o  Remove PROJ.4 dependency, functionality and related API
>     With PROJ 6 being released and removing completely projects.h old API,
>     a major upgrade would have been needed. I'd rather choose to completely
>     cut off PROJ related functionality from OGDI.
>     For the VRF case, projection support can be done through the GDAL/OGR
>     OGDI driver.
>     The dtusa and dtcanada drivers are removed.
>     The following functions are removed from ecs_util.h:
>     cln_SetServerProjection
>     cln_SetClientProjection
>     cln_ProjInit
>     cln_CompareProjections
>     cln_ConvRegion
>     cln_ConvTtoS
>     cln_ConvStoT
>     cln_ChangeProjection
>     cln_ChangeProjectionArea
>     cln_ChangeProjectionLine
>     cln_ChangeProjectionPoint
>     cln_ChangeProjectionMatrix
>     cln_ChangeProjectionImage
>     cln_ChangeProjectionText
>     ecs_distance_meters
>  o  Update server version to 4.0 to reflect removal of SetServerProjection
>     capability
>  o  Build: add -fPIC when required
>  o  Rename aclocal.m4 to acinclude.m4 and apply stricter quoting
>  o  Respect LDFLAGS provided to ./configure
>  o  Fall back to libtirpc if libc does not provide rpc/rpc.h
>  o  Don't hardcode compiler to fix cross compilation.
> I've verified it works fine with GDAL/OGR OGDI driver with the VRF OGDI
> driver of both GDAL 2.4 and GDAL master, since GDAL does not use the now
> removed OGDI PROJ capabilities
> Sourceforge CVS being now read-only, upstream development is now definitely
> at https://github.com/libogdi/ogdi
> I'll promote this RC to final if there are no serious issues reported.
> Even
http://www.spatialys.com
