[gdal-dev] libgeotiff 1.5.0 release candidate
Even Rouault
even.rouault at spatialys.com
Wed Mar 13 15:49:41 PDT 2019
I've prepared a libgeotiff 1.5.0 release candidate, aka "libgeotiff freed from
CSV files". So download and try:
https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.5.0RC1.tar.gz
https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.5.0RC1.zip
If nothing serious is reported, I'll issue a motion next week to MetaCRS for
offcial adoption.
The news are:
* Require PROJ >= 6 dependency
* Remove all CSV files used by geo_normalize API, since libgeotiff now relies
on PROJ database for EPSG CRS definitions.
* geo_normalize.c: SetGTParmIds(): use ProjStraightVertPoleLongGeoKey for
CT_PolarStereographic
* geo_normalize.c: report StdParallel1 for Mercator_2SP when a PCS code is
used
* geo_normalize.c: fix support for Laborde Oblique Mercator
* listgeo: use PROJ database to display non-hardcoded values of a number of
keys
For info, GDAL 2.4.0 builds against it (after re-adding a few symbols that are
no-op now) and seems to work properly in quick basic manual tests, although
moving the whole stack will require further advances in PROJ 6.0 adoption. The
natural set of compatible versions (and the one actually tested by continuous
integration) will be more GDAL 2.5.0 + libgeotiff 1.5.0 + PROJ 6.0
Best regards,
Even
http://www.spatialys.com
