[gdal-dev] Export to Geopackage
Randal Hale
rjhale at northrivergeographic.com
Thu Mar 14 08:11:42 PDT 2019
If I export a postgis table to geopackage:
ogr2ogr -f GPKG export.gpkg PG:"host=gis1 user=rjhale dbname=dbname
password=pass" -nln "addresspoints" -sql "select id, geom, addresses"
I check the geopackage:
rjhale at gis7:~/temp$ ogrinfo -so -al TCStransport.gpkg
INFO: Open of `TCStransport.gpkg'
using driver `GPKG' successful.
Layer name: addresspoints
*Geometry: Unknown (any)*
Feature Count: 23735
Any idea on what I'm doing wrong - the unknown geometry seems to be
causing an issue in another process. If I export without the SQL
statement everything is fine.
Randy
Randal Hale
https://www.northrivergeographic.com
(423)653-3611
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190314/f773189c/attachment-0001.html>
