[gdal-dev] Intermittent raster read/write error
Even Rouault even.rouault at spatialys.com
Thu Mar 14 09:17:17 PDT 2019
Jon,
> Is there a better way to determine that a write has failed? We've enabled
> gdal.UseExceptions, but if you call rb.WriteArray() on a read-only dataset,
> no error is raised. There is a write to stderr, but no exception.
The RasterIO() method called by WriteArray() didn't check access mode, so for
small enough write w.r.t GDAL block cache, the error was only caught when
dirty blocks in cache were actually written to storage by explicit
FlushCache() or dataset closing.
I've a candidate fix https://github.com/OSGeo/gdal/pull/1364 to address that.
Even
http://www.spatialys.com
