[gdal-dev] vsistdin and VRT
Even Rouault
even.rouault at spatialys.com
Fri Mar 15 08:26:16 PDT 2019
On vendredi 15 mars 2019 18:14:48 CET Nikolai Bezdna wrote:
> Can vsistdin be used in VRT source definition?
> So that one can use output from another utility (osmium in my case) as a
> valid OGR source.
The general answer is No. This depends a lot of the underlying driver (the
format must allow sequential reading), and how you use it afterwards.
A particular case where this might work is a VRT referencing CSV:/vsistdin/
and using that vrt as the source for ogr2ogr
For example with test.vrt being:
<OGRVRTDataSource>
<OGRVRTLayer name="test">
<SrcDataSource>CSV:/vsistdin/</SrcDataSource>
<SrcLayer>layer</SrcLayer>
</OGRVRTLayer>
</OGRVRTDataSource>
you can do:
cat test.csv | ogr2ogr -f GML out.gml test.vrt
Even
http://www.spatialys.com
