[gdal-dev] NetCDF: North is left
Markus Metz
markus.metz.giswork at gmail.com
Mon Mar 18 09:49:54 PDT 2019
I have a NetCDF file with
Size is 1800, 3600
Coordinate System is `'
Origin = (89.999996946545821,179.999996947394237)
Pixel Size = (-0.099999996607273,-0.099999998304108)
Metadata:
Latitude#long_name=Latitude
Latitude#units=degrees_north
Latitude#_CoordinateAxisType=Lat
Longitude#long_name=Longitude
Longitude#units=degrees_east
Longitude#_CoordinateAxisType=Lon
Geolocation:
LINE_OFFSET=0
LINE_STEP=1
PIXEL_OFFSET=0
PIXEL_STEP=1
SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
X_BAND=1
X_DATASET=NETCDF:"LPRM-AMSR2_L3_DS_A_SOILM3_V001_20190301000851.nc4":Longitude
Y_BAND=1
Y_DATASET=NETCDF:"LPRM-AMSR2_L3_DS_A_SOILM3_V001_20190301000851.nc4":Latitude
Corner Coordinates:
Upper Left ( 90.000, 180.000)
Lower Left ( 90.000, -180.000)
Upper Right ( -90.000, 180.000)
Lower Right ( -90.000, -180.000)
Center ( -0.0000000, -0.0000000)
-> apparently north is left and east is up
Is there any way to rotate this subdataset with GDAL tools? gdalwarp -s_srs
EPSG:4326 -t_srs EPSG:4326 does not work.
Do I have to add GCPs with gdal_translate?
Thanks for any hint!
The problem file is here:
https://hydro1.gesdisc.eosdis.nasa.gov/data/WAOB/LPRM_AMSR2_DS_A_SOILM3.001/2019/03/LPRM-AMSR2_L3_DS_A_SOILM3_V001_20190301000851.nc4
Markus M
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190318/d1f03b19/attachment.html>
