[gdal-dev] NetCDF: North is left
Markus Metz
markus.metz.giswork at gmail.com
Tue Mar 19 10:13:19 PDT 2019
Even,
On Tue, Mar 19, 2019 at 4:53 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Markus,
> yes this file has unconventionnal indexing of variables, with the fastest
> varying dimension being latitude, which confuses the driver
> In https://github.com/OSGeo/gdal/pull/1377, I've made a number of changes
that
> make support of such dataset a bit easier. I didn't go to making the
driver
> autocorrect the swapped axis, but did a number of fixes so that the
> geotransform and Geolocation array metadata are correct (and also improve
the
> geoloc transformer/wrapper to deal with such swapped axis)
> With those fixes, the following does the right thing:
> $ gdalwarp -geoloc NETCDF:"LPRM-
> AMSR2_L3_DS_A_SOILM3_V001_20190301000851.nc4":ts /tmp/out.tif -overwrite
thanks a lot!
But looking at all the datasets with weird georeferencing out there in the
wild, it would be really ambitious to come up with a fix at driver level...
> Without it, you can indeed have the expected result by setting GCP
This is what I ended up doing, it works just fine, also in an automated
processing chain.
Markus M
> $ gdal_translate \
> NETCDF:"LPRM-AMSR2_L3_DS_A_SOILM3_V001_20190301000851.nc4":ts \
> tmp.vrt \
> -gcp 0 0 -180 90 \
> -gcp 1800 0 -180 -90 \
> -gcp 0 3600 180 90 \
> -gcp 1800 3600 180 -90
> $ gdalwarp tmp.vrt out.tif -order 1 --config GDAL_NETCDF_BOTTOMUP 0
-overwrite
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190319/d87ec4b2/attachment-0001.html>
