[gdal-dev] Set gdal option at compile time
Armin Burger
armin.burger at gmx.net
Wed Mar 20 14:26:26 PDT 2019
On 20/03/2019 22:01, Even Rouault wrote:
> On mercredi 20 mars 2019 21:06:21 CET Armin Burger wrote:
>> Dear all
>> is it possible to change the default value of a GDAL option at compile
>> time?
> No
> Must be done at runtime. Can be done by setting it for example as environment
> variable in your batch script.
> Even
Thanks for the quick reply.
When opening a file, gdal checks for various sibling files, like *.AUX,
*.aux.xml, etc. Is there a sort of configuration file that defines for
which files and file extensions gdal is searching for any file open?
Best
Armin
