[gdal-dev] Help with GDAL/OGR Python API and OCI
Even Rouault
even.rouault at spatialys.com
Mon Mar 25 16:56:29 PDT 2019
On lundi 25 mars 2019 17:26:17 CET Alejandro Saucedo wrote:
> Hello,
> Please, your help with the following problem.
> I am not able to see the Oracle OCI driver from python using the GDAL/OGR
> bindings.
> The following code prints always None:
> from osgeo import ogr
> print(ogr.GetDriverByName( 'OCI' ))
> Also, the driver is never listed here:
> drivers = [ogr.GetDriver(i).GetDescription() for i in
> range(ogr.GetDriverCount())]
> drivers.sort()
> print(drivers)
> ['ARCGEN', 'AVCBin', 'AVCE00', 'AeronavFAA', 'AmigoCloud', 'BNA', 'CAD',
> 'CSV', 'CSW', 'Carto', 'Cloudant', 'CouchDB', 'DGN', 'DXF', 'EDIGEO', 'ESRI
> Shapefile', 'ESRIJSON', 'ElasticSearch', 'GFT', 'GML', 'GMLAS', 'GPKG',
> 'GPSBabel', 'GPSTrackMaker', 'GPX', 'GeoJSON', 'GeoRSS', 'Geoconcept',
> 'HTF', 'HTTP', 'Idrisi', 'Interlis 1', 'Interlis 2', 'JML', 'JP2OpenJPEG',
> 'KML', 'LIBKML', 'MBTiles', 'MVT', 'MapInfo File', 'Memory', 'NAS', 'ODS',
> 'OGR_DODS', 'OGR_GMT', 'OGR_PDS', 'OGR_SDTS', 'OGR_VRT', 'OSM', 'OpenAir',
> 'OpenFileGDB', 'PCIDSK', 'PDF', 'PGDUMP', 'PLSCENES', 'PostgreSQL', 'REC',
> 'S57', 'SEGUKOOA', 'SEGY', 'SQLite', 'SUA', 'SVG', 'SXF', 'Selafin',
> 'TIGER', 'TopoJSON', 'UK .NTF', 'VDV', 'VFK', 'WAsP', 'WFS', 'WFS3', 'XLS',
> 'XLSX', 'XPlane', 'netCDF']
> However, OCI can be used in command line with ogr2ogr and it is listed when
> executing ogrinfo --formats:
> OCI -vector- (rw+): Oracle Spatial
> My environment is as follows:
> RHOL 7, GDAL 2.3.3, Python 3.6 (with Numpy 1.16.1), Oracle Instant Client
> 18.5
> I have tried building the python bindings using the following alternatives:
> 1) Building the python bindings with the GDAL source tree:
> ./configure --prefix=<GDAL_PREFIX> --with-curl=/usr/bin/curl-config
> --with-python=<PYTHON3.6_BIN>/python
> --with-oci-include=$ORACLE_HOME/sdk/include --with-oci=$ORACLE_HOME
> 2) Downloading the python bindings from
> https://pypi.org/project/GDAL/2.3.3/#files and running setup.py
> build/install process
> 3) Using pip install GDAL==2.3.3
> The result is the same always, I can use the GDAL/OGR python API but cannot
> see or use the OCI driver (the same for GeoRaster).
> As suggested at
> https://trac.osgeo.org/gdal/wiki/BuildingOnUnix#OCIwithoutinstallingOracle,
> I have my ORACLE_HOME variable pointing to the instantclient folder,
> ORACLE_HOME is also present at the PATH and LD_LIBRARY_PATH env vars as it
> is GDAL/bin and GDAL/lib respectively.
I presume the shared libraries of the python bindings link to another version
of the GDAL lib than the one that you've built.
Locate _gdal.cpython-36m-x86_64-linux-gnu.so (or something like that), and run
ldd on it to see to which libgdal it links to
http://www.spatialys.com
